Freezes while composing message Thunderbird 138/139, Windows 11, in safe mode and troubleshoot mode
Thunderbird 138/139, Windows 11 Pro 23H2. While composing a message, after a few lines the app freezes. Both the compose window and the main TB window freeze. Only opening the Windows Task manager allows me to close them. This did not happen with earlier versions.
If I save the message every few seconds while composing I can get most of the message back and continue after restarting TB. This behavior is the same in both the normal and troubleshooting TB modes. I can't even find a crash log to send to Mozilla.
Where shall I look next?
Thank you!
Modified
All Replies (6)
Sorry you are having trouble.
Freezes do not create crash reports. Have you posted this issue anywhere else?
Wayne, thank you for your answer. No, I have not posted elsewhere. Could you suggest where the most productive places to post might be?
Thanks again!
I suggest you do not post anywhere else. I only asked so I could determine whether what I saw elsewhere was you or not.
- Start Windows in safe mode with networking enabled - https://support.microsoft.com/en-us/help/12376/windows-10-start-your-pc-in-safe-mode
- Still In Windows safe mode, start Thunderbird in Troubleshoot Mode - https://support.mozilla.org/en-US/kb/troubleshoot-mode-thunderbird
Does problem change?
No, the issue repeated with both Windows and TB in safe mode. It took a couple of minutes after I began composing.
Do you have a signature specified for the account, which appears in the compose window? Is the compose window plain text? Or html?
Yes, I use a signature which is a JPG image.
Messages are HTML.
Thanks!
